NMace
Dec 13, 2013Explorer
CheapHeat System?
In the Dec 2013 issue of TRAILER LIFE magazine there is an article on the CheapHeat after-market electric system. I was shocked to read the authors proclaim even additional savings when in camp gro...
PawPaw_n_Gram wrote:iawoody2 wrote:
The problem with using portable electric heaters is that you are not getting heat to the underbelly if needed due to outside temperature.
All three of the systems CheapHeat sells are furnace replacements/ supplements - with provide all the benefits of ducted heat as do propane furnaces.
The one big downside I see is the HT-37 system for 50Amp service trailers. If you are connected to 30Amp - the heater will not heat at all. You must be connected to 50Amp.
