RickLight wrote:
Lantley wrote:
Typically the pedestal has a 30 amp and 20 amp outlets available.
Seldom is there only a 30 amp only outlet, although I have seen a few.
The transfer switch allows you to "cheat" or make use of that additional outlet, to power the 2nd A/C.
It works very well.
Typically they aren't additive. It gets back to how the place is wired, but just because there are outlets doesn't mean you can load them all full at the same time.
I understand your point. I also own an RV Safepower switch. I have used it successfully quite a few times. While I understand it's possible that the wiring will not accommodate the switch. I have yet to be on a 30 amp site where my transfer switch has not worked. So far I am batting a 1000 which is good enough for me.
Those that have not actually used the transfer switch or experienced the benefits of the switch first hand can draw an conclusions they like.
For me so far it's worked 100% of the time.
The switch has changed my camping itinerary and allowed me to use state parks again. Places I had avoided, do to only having 30 amp sites are now back on my agenda. Having the ability to run both AC's on a 30 amp site is a game changer.
