- 45RicochetExplorer
Okie1 wrote:
Same here....rockhillmanor wrote:
You will get a myriad of answers on that question. From magic water softeners concoctions to ice to doing nothing. :R
For years and years there have been holding tank chemicals for marine and RV holding tanks. They were made for a reason. Your holding tank is not your mommas house sewage system. We have small pipes, bends and blades and sensors on the inside. All places for stuff to stick and clog.
If you don't want garbage stuck all over the inside of your tank and sensors, smells when you flush coming up into your RV, and don't want to experience clogs in the pipes and valve blades to ruin a good camping trip use this. All the others just add 'perfume' to the tank and does nothing but smell up your RV with a nasty perfume smell.
Thetford makes 2 types one to appease the greenies and this one. The labels look similar. Be sure to read the label and it says breaks down waste and powerful odor control.
20 years on the road now and my sensors always work and I have never had one incidence of sewer smells in the MH zip zero.:W
X3 DW has a good nose - Not_a_ClueExplorer
fairhaven wrote:
Happy Camper is the best stuff, easiest stuff I have found in 40 years. You can buy it from their web site 5starhappycamper.com. If there is a better product I am not aware of it.
Good stuff.... - kakampersExplorerWe use this...Blue Streak
It's an automatic dispenser, so you don't need to fool with it each time you dump...just fill the reservoir and forget it, till the water in the bowl turns clear. Best product we have found...:B - Okie1ExplorerSame here....
20 years on the road now and my sensors always work and I have never had one incidence of sewer smells in the MH zip zero.:W - fairhavenExplorerHappy Camper is the best stuff, easiest stuff I have found in 40 years. You can buy it from their web site 5starhappycamper.com. If there is a better product I am not aware of it.
- NHIrishExplorerAs others have said, it's a holding tank, not a septic system....but odors can be a problem in warm weather.
I normally stay a couple weeks at a time on a spot...often without sewer connections. Holding tanks (black and gray) can get pretty funky in two weeks.
Mr. Green is he best product I have ever used for holding tank odor.
It used to be hard to find, but is now available at Amazon, Walmart etc. It's good stuff.
http://www.mrgreenusa.net/MrGreen-Marine-Holding-Tank-Treatment/dp/B003QKLV36 - d_eggman2ExplorerWe started the geo method last summer. And so far it has worked perfectly.
The only addition we add is a cascade platinum pod after dumping and 3-4 buckets of water. - paulcardozaExplorerIf you feel the need to use something, the Campa-Chem product above is a good choice. About $1/bottle in 6-packs @ Wally World. We use nothing but lots of water when flushing. We use the tank flush every 3rd or 4th dump, depending on how much time I have to spend on it.
- DonPdExplorerThe Geo Method is good but if you want a product that I found that work try this;
http://www.uniquedistributing.com/product_info.php?products_id=94
I did find it at ACE hardware stores.
Also, get a clear drain hose fitting so you can see what is coming out of your tanks and when they are empty.
http://www.campingworld.com/shopping/item/rhinoflex-clear-swivel-fittings-45-fitting/59254
One of the most important thing is RV safe TP. Watch this video on how to check your TP.
http://www.youtube.com/watch?v=eDLXXRVe2pc - rockhillmanorExplorer IIYou will get a myriad of answers on that question. From magic water softeners concoctions to ice to doing nothing. :R
About Fifth Wheel Group
19,026 PostsLatest Activity: Oct 22, 2025
