MFL
Feb 18, 2021Nomad II
Well if you believe the forums, you will need a bigger truck, no matter the size of trailer!! :) A diesel will pull that wt, with less effort, but the gasser will work, for your use!
Your truck should do a great job, towing that trailer, even if loaded to the full GVWR! That should be a good FW too. While I have no experience using one, they have a good rep.
If you are within your RAWR/tire rating, which you will be, unless you fill the bed with rocks, you are GTG!
If you have the FW hitch puck system, you need to look at the B&W 3700.
Jerry
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
