JFit23's avatar
JFit23
Towing with Chevy Avalanche will it be safe?
It seems the more I research this topic, the more confused I get.
here's the rundown:
2004 Chevy Avalanche 1500 4WD
Curb weight 5700 lbs
GVWR 7,000
looking to get a LivinLite Bearcat 16fk which dry is 3100 lbs with tongue weight of 640 (dry), that seems quite heavy.
The payload on the Avalanche is only 1300 lbs, so with me, the wife and 2 large dogs, we're at 550lbs added there.
Add int he tongue weight of the Bearcat unloaded and I'm basically at the max payload of the Av.
We won't be loading any "toys", I just like the TH layouts for dogs.
Livinlite doesn't recommend WD setups as you have to drill into the frame. Ok, so Andersen hitch has WD w/o drilling.
From my reading, all this does is transfer off the rear axle and distribute it to rear/front, not really helping my payload issue.
or am I missing something here?
Does the WD hitch put some of the TW back on the trailer?
Also, if I fill the freshwater tank which is located near the front of the trailer, not sure how far up, how much would that add to TW?
can anyone help me here?
