Searching_Ut wrote:
I've been checking the pin boxes of rigs I see with the andersen ultimate after
the 1621HD on my rig was damaged by the hitch adapter. I have seen seen damaged MR pin boxes. All the pin weight is carried on just the two pins between the ball and the pin teeter totter fashion which the pin boxes weren't designed for. I would recommend going with the heavy duty plate or getting a shim from Andersen to distribute the weight better.
What are you talking about?? The weight is carried in the same place as normal, right at the pin! The set bolt holds the adapter in the pin groove with the large bolts. The 4 set screws keep it from spinning and moving. There just doesn't seem to be any merit to your post
Chris
