Old-Biscuit
Jan 30, 2017Explorer III
Internal check valve in on-board pump leaking allowing backflow thru pum
OR
If you have a water panel with 'FILL' position it is leaking thru allowing water to go to fresh water tank
No 'FILL' valve then pump check valve
Run pump and let the flow thru pump clear check valve diaphragm of debris/scale....hopefully.
I never use city water directly any more......
Fill tank and always use pump.
Had a fitting break while on city water flooded rv $6000 damage.
OR
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
