NC Hauler wrote:
I probably would have asked the question on the Class A forum...Most on here own 5th wheels...
I've looked at Class A's, but still like 5th wheel over it...I paid less for my truck and my 5er than I would have paid for a comparable Class A...Other than that, there probably will be those that have gone from an A to a 5er and can tell you about that, and I would imagine, as usual, they'll be a Class A owner or more come onto this forum and tell you the pro's on their class A....
yes - ask on the Class A forum.
Many folks here went the other way.
A lot (awful lot) depends on the depth of your wallet - for initial cost and maintenance.
Whether it's gas or diesel - figure at least double the cost for any drive line work - over a pickup.
Some shops aren't equipped to work on MHs - period.
(Check on wayxm's posts for his blown gas engine)
Go over to the IRV2 forums - which has a forum for many brands of MHs.
Follow along on the cost of drive line maint & repairs.
Also - no matter which you have, you will most likely be towing "something". (Class A = a "toad", Pickup = some kind of trailer)
Good luck with whatever "adventure" you choose.
BTW - I've had 2 (gas) A - MHs, Two TTs, one 11 1/2' TC, and a 5th.
If I was going to spend lots of time traveling, and had unlimited resources - I might consider a DP MH.
But - after inputing that thought.....Nyet!
Rather have a singled HDT (Smart car on the deck) with top-of-the line New Horizons 5th.
An HDT with sleeper is the best of both worlds - Tow Vehicle and MH - & can be used as a daily driver if desired.
Best of both worlds (TV & MH).
Way, way easier (and less expensive) maint & repairs than the DP, and will "out-tow" and "whoa!" better than anything on the road.
Choices, choices - - decisions, decisions - so little time!
Have fun, spend wisely!..:C
