schlep1967
Jul 03, 2013Nomad
Odds are if mold was in the tank it is in all the lines and the hot water heater. Drain the hot water heater. Put a mixture of bleach and water in the tank and use it to fill the hotwater heater. Then run the mix through every outlet. Let it sit for a day then run more through. If you do not drink the water you could put a cup or so of NONSCENTED bleach in the tank every time you fill it. It will be dilutued enough that it will not hurt anything but strong enough to keep the mold at bay.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
