Swamp_Man
Jul 07, 2013Explorer
How are things coming along? Did you get all of the black mold out of the tank and system? I got to thinking and thought that it might be safer to remove the discharge line from your pump and pump the "killed" contents of the tank out in a sewer rather than through the water system. Once you have the tank clean and safe, you could pump from the tank with the bleach solution into the rest of the system. The system will then drain into your gray and black tanks. Remember to work the john also as fresh water is used in it just in case some of the water were to backflow. Anyway, let us know how this turned out.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
