laknox wrote:
Jerry_L wrote:
I've been seeking advise as to the best method/substance to use to clean out the black holding tank. I've seen videos suggesting bleach and peroxide while other suggested to stay away from those to substances. I found a product on line called "TankTechs RX" probiotic tank treatment. Has anyone used this product and is it worth while to purchase? The rv dealership I use is expensive and expressed reluctance to clean the tank (I'm in the process of finding a more receptive dealership). We've had sensor problems and I believe it has to do with the tank even though I flush the tank a minimum of three times. Any suggestions?
All the OEM sensors are notoriously inaccurate. Use lots of water with the black tank and drop a treatment packet or dose into the tank. Do a search on the "GEO method" of black tank treatment. Basically, it's Calgon (or other water softener powder) and original Dawn dish soap. Mix it up, drop a cup or 2 into the tank, and it helps slick things up to keep the "stickage" down. A 20 lb bag of ice in 3-4 gallons of water, then driving, can help break up more solid piles. After you dump, always put 3-4 gallons of water back in, even for storage. You just don't want it to dry out. Many RVs use a black tank flush built in; you can also get a clear elbow that goes on the dump pipe to attach a garden hose to to back-fill the tank. As one poster said, you can buy or make a wand to go down from the top, but I consider that a last-ditch solution for a problem tank. In 10 years, I've had only 1 instance of the "poop pyramid" because I was in a water conservation mode and just flat didn't use enough water. Dump, fill, dump, fill, then dump the grey tank to rinse out the hose.
Lyle
Good advise (advice).
The wand suggested by the "one poster" has a MH.
For 5ths, usually there are bends in the plumbing and the tank.
The "clear elbow" will do a good job......but, as many stated - the sensors are unreliable even when the tank is "clean".
Gotta wonder how a black tank can ever be "clean" (or why it should).:h
