Jerry_L wrote:
I've been seeking advise as to the best method/substance to use to clean out the black holding tank. I've seen videos suggesting bleach and peroxide while other suggested to stay away from those to substances. I found a product on line called "TankTechs RX" probiotic tank treatment. Has anyone used this product and is it worth while to purchase? The rv dealership I use is expensive and expressed reluctance to clean the tank (I'm in the process of finding a more receptive dealership). We've had sensor problems and I believe it has to do with the tank even though I flush the tank a minimum of three times. Any suggestions?
All the OEM sensors are notoriously inaccurate. Use lots of water with the black tank and drop a treatment packet or dose into the tank. Do a search on the "GEO method" of black tank treatment. Basically, it's Calgon (or other water softener powder) and original Dawn dish soap. Mix it up, drop a cup or 2 into the tank, and it helps slick things up to keep the "stickage" down. A 20 lb bag of ice in 3-4 gallons of water, then driving, can help break up more solid piles. After you dump, always put 3-4 gallons of water back in, even for storage. You just don't want it to dry out. Many RVs use a black tank flush built in; you can also get a clear elbow that goes on the dump pipe to attach a garden hose to to back-fill the tank. As one poster said, you can buy or make a wand to go down from the top, but I consider that a last-ditch solution for a problem tank. In 10 years, I've had only 1 instance of the "poop pyramid" because I was in a water conservation mode and just flat didn't use enough water. Dump, fill, dump, fill, then dump the grey tank to rinse out the hose.
Lyle
