cummins2014
Oct 10, 2020Explorer
md_procouple wrote:
After a couple of years being dormant, our 5'er has developed oxidation problems. I have been removing the peeling decals and everywhere where the decals were, the "finish" is still shiny and pristine looking. But everywhere else developed the oxidation issue. I saw an "oxidation" remover from Meguires for fiberglass boats and campers. Which I was told would work from the salesclerk. Although I did not feel comfortable with his answer. The other option is I have a pressure washer and would that work as well. (It would be a lot Quicker for sure.) But I am not sure it would be the correct way of doing it. I would NOT use it on the roof. Just the sides and front Cap. Any suggestions would be greatly appreciated.
Try as I might on my previous fifth wheel I never could get the oxidation off to match where the graphics had been ,if that is what you are asking ?? I was just going to eliminate a few of the peeling graphics, but getting the oxidation off to match was not working with the products I was using. I finally replaced a few of the graphics, on others I just trimmed them back a bit. It got to the point trimming them I was getting a shinier ring around the graphics where they had been ,and I couldn't wax off the oxidation to match .
I know it can be done ,but using a couple different products ,plain old rubbing compound did not get the job done, nor a couple others that I don't remember ,but was advertised to remove oxidation.
I have watched a couple youtube videos on removing decals ,and oxidation on the front caps, and it was quite a process. Something I am not willing to do. Good luck with the project .
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
