Old-Biscuit
Feb 11, 2014Explorer III
You are going to have to accomplish two things.
Get bed rail clearance......raise the hitch/lower the pin box
And then get rid of nose high condition (not good) by flipping axles (if the springs are mounted under axle tubes), by cutting spring shackles off/welding square tubing on frame (2",3" etc) and then welding shackles back on OR if you have adjustment holes in shackles change mounting position to lowest holes.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
