Cummins12V98
Feb 11, 2014Explorer III
Hotel California wrote:
I was about to place an order for a 2014 3500HD 4x4 Ram, but went to dealer's lot first to take some measurements. If I want to tow my fifth wheel level, it looks like I'm only going to have 2 inches of clearance between the bed rails and the underside of the fifth wheel nose.
Currently have a 10 year old GMC Duramax 2500HD 4x4 with plenty of clearance. The height of the new Ram bed is 2.5 inches greater than the Duramax and the depth of the bed is 2 inches greater. That puts the RV 4.5 inches closer to the bed rails if I keep the RV level!
I could raise the fiver hitch height and lower the pin box, but that's going to make the RV tow with the nose up and tail down.
Am I understanding and calculating this correctly?
Probably an optical contusion but your RV looks low in the front in your pic. It won't hurt a thing to be a bit high in the front. The RAM's have a lot of spring travel. I bet you would be fine. Do you have spring hanger adjustments on your RV?
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
