charfar1ExplorerAug 25, 2014coachmen 5th wheel slide periodically worksFriend has a coachmen 5th wheel and rear slide will not work using wall switch. If you take a wrench and start to move wall manually just a slight bit the wall switch begins to work fine both in and o...Show More
Related ContentLeaving rig someplace to fly home periodically?Water pump on fiver periodically pulses1982 Coachmen 15' rebuild2019 Coachmen Leprechaun Winterizing?Coachmen Galleria Li3
