taken
Oct 25, 2015Explorer II
Which Trail Air product are you actually comparing to the MorRyde? The original Trail Air and the Trail Air Tri-Glide are discontinued but are still available in from retailers. The new boxes from Lippert are the Flex Air (combines the MorRyde type rubber system with an air bag for vertical cushion) and the Air Ride (same as the old Trail Air). There is a member here with the handle crazycooter who tried the new Flex Air with VERY poor results. I'd search out his post if you are considering that box. The Air Ride (formerly called Trail Air) is ok but the Reese 5th Airborne is identical in performance but much better looking with it's guts on the inside. I had a Tri-Glide and was less than impressed with it's loose for and aft motion. No experience with the MorRyde but it has a lot of happy customers.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
