srl520's avatar
srl520
Considering TH with challenging tow
Looking at giving up the TC for TH for the sand.
Problem:Towing with a GMC 4500 4x4. Stock box height is 69". Replacing the box for flat bed is a no go wife says.
So looking at triple axle 30-32' bumper pull.
Problem: Needing to transport Jeep which weighs around 3500lbs. Reading that is to much weight hanging off the back end.
So looking at older 5'er that is lower profile. Considering axle flip. Possibly adding 2-4" rectangular square tubing lift between frame and shackles.
I know that will raise the center of gravity and possibly be stability issues. I need to keep OA height under 14'.
What are the experiences from the peeps that have tried to over come this problem?
