GPG52_
May 29, 2015Explorer II
Hi Iaknox, You have seen my previous response on the "regular vs. lite weight" forum We enjoyed the Durango KZ 1500 but moved up due to.
"I have owned both a Durango 1500 series and Cougar 327RES. Both worked great for us. Here are some things we noticed with the lite unit.
- Walls are thinner... which means less insulation
- The framing was based on the box configuration vs. having evenly spaced wall studs. I.E: framing around the perimeter of the box, around the door but then large gaps between studs
- limited amount of pull outs and the pull outs were not as deep
- some models have less hanging cupboard space as the walls have less framing
- oven was small... although the stove surface had three burner.. the oven interior height was shallow and would not fit standard cooking pots restricting its use.
- and my PET PEAVE the electric awning was anchored in the wall skin only and not in a stud.... first year we were caught in a freek storm which tor the awning arm away from the wall... this compromised the awning reducing it to a fair weather awning going forward.
My 2c worth... good luck.
GPG
GPG
About Fifth Wheel Group
