Jerry_B
Mar 11, 2014Explorer
Me Again wrote:
The GY G614 is GY high end trailer tire. It is the same diameter as the Marathon ST235/80R16E. Rating goes for 3420 with the Marathon to 3750 with the G614. However your wheels have to be able to handle 110 inflation to use the full 3750 rating. What is the listed GAWR and GVWR on the placard on the left from corner?
There is another LRG tire in the Sailun that cost a lot less, however it is larger in diameter, so you need at least 33+ inches between the axles. Being a TH you should not have clearance issue above the tires.
http://simpletire.com/sailun-235-85r16-8244393-tires
Just about 99.99 percent of ST tires will perform similar to the ones you currently have. So if you what to get off that treadmill then you need to go to higher quality tires.
Chris
What is the issue with the necessity for 33inches between tires. I am considering buying the Sailuns. Thanks.
About Fifth Wheel Group
