mileshuff
Nov 08, 2013Explorer
There are online sources that will tell you your tire dimensions. For ST235/80R16's you have 2 LT choices unless you can/want to go to a much larger or smaller size or change rim sizes.
The LT245/75R16's are very close to the same height and about .25" or less wider. The LT235/85R16's are about 1" taller and about the same width.
I went with the LT245/75R16 Michelin XPS Rib. My existing tires are on 6.5" rims. The Ribs manufacture width lists them at .25" wider but thats using 7" rims. When mounted on my 6.5" rims the width is just barely wider than the ST's. A very close match.
ST tires generally have a higher load rating than LT's but its difficult to compare. ST tires show the absolute max rating not to exceed. The LT tires typically are underrated by 20% to allow a safety margin.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
