B_O__Plenty
Nov 08, 2013Explorer II
waltbennett wrote:If you compare them side by side (I have) you will find you have that backwards. My old Tow Masters were like bicycle tires compared to the Michelin Ribs I now have. You could grab one of the Tow Masters and wrinkle it up with one hand. In addition the Michelins weigh about 20 pounds more...The weight ratings are less with an LT tire over an ST tire but don't let that stop you. I replaced a 235/80/16 load range E ST tire with a 235/85/16 load range E LT tire. Mine have been trouble free for thousands of miles.
The numbers and ratings are the same. Only change is the letters. Truck tires have more flexible side walls as they may be on steerable wheels, trailer tires have stiffer sidewalls as they won't be steering.
B.O.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
