ol_Bombero-JC
Nov 08, 2013Explorer
Red wing wrote:
Hi everyone
How do you convert ST tires size to LT tires size? For example 235/80R/16 load range E to a light truck tire size.
Google is your friend..:C
Enter: "tire size conversion" (etc) -
several sites avail to enter size of tire you have -vs- tire size you are considering.
Results are in inches.
Handy for your example, as there are few (if any) LT tires available in 235/80.
You will have to go to 235/85 - check the diameter of the new tire size for clearance (between tires) via the conversion site.
Remember an inch larger in diameter results in loss of 1/2 inch per side - one inch total between the tires.
(235/85 is an increase of 1" in diameter over 235/80)
If it's inadequate - go to a different size, ex: 245/75
(which will be the same diameter, but 1" wider).
Be sure to check the wheel pressure rating - usually stamped on the back side of the wheel.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
