mileshuff
Nov 08, 2013Explorer
ol Bombero-JC wrote:
If it's inadequate - go to a different size, ex: 245/75 (which will be the same diameter, but 1" wider).~
245/75's are about 1/4" wider than the 235/80's. However, it most likely is less. The measuring rim used for manufacture specs on the LT245/75 is often 7" while on the ST235/80's it is 6.5". Thus if you mount a 245/75 on a 6.5" rim you'll be less than the 1/4" spec difference.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
