hoopers
Nov 11, 2013Explorer
Replacing ST tires with LT tires can be a confusing and daunting task, especially if you have never done it before. There are hundreds of threads on this 4m alone about the subject. It really depends on the weight each of your trailer tires is expected to carry.
Typically, the same size ST tire will be rated higher than a corresponding LT tire. However, there are some Goodyear tires that buck that trend. Most ST tires are specified at 62 MPH max, whereas LT tires are specified at higher speeds. Personally, I think this is one of the reasons for so many ST tire failures...you should go slow (< 62 mph) on them at all times.
I know many people simply buy a top end LT tire, and call it good. But many others, including me, made the decision to make sure each tire was specified to carry the weight placed on it.
Here is one link that helped me a lot, and has been posted on this 4m many times before:
Linky
Linky
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
