Bad Brad wrote:
My batteries were very weak so I plugged my trailer in to my garage power tonight. Interestingly, the lights were very dim and certainly running off the batteries only. In the past, the lights were very bright as soon as the trailer was plugged into shore power. Is this an indication that the converter has failed?
Thanks,
Brad
Did you notice a 'brightening' of the lights when you plugged into shore power? You can test at the battery via a multi meter; you should see an increase in voltage when the shore power is lit and the inverter starts charging your batteries.
If you don't have any voltage coming out of the inverter you have an issue, maybe a fuse blown.
