rhagfo
May 28, 2016Explorer III
chrizg wrote:
Max pressure. While in Elkhart I talked to the main tire supplier there and I asked this same question. They said trailer tires should always be at max and if you have a blowout and request warranty coverage and you tell them you run it below max pressure they will deny the claim.
That is because trailer manufactures always put a minimum tire on trailers. What I mean by that is the tire is carrying right at or just under the maximum weight the tire is rated to carry! Once you chose to upgrade the tires to a much higher capacity, then things change. There isn't a tire on my whole rig that runs at max pressure. I value traction too much to do that. You might try the tape test across the tread. I'm
About Fifth Wheel Group
