Usnthedog wrote:
I know this gets touched on occasionally but I'd like to see a full discussion. I have load rating E tires. 3450 lbs at 80 psi. I run about 5000 lbs per axel. I've seen the ratio addressed: 2500/3450 * 80 = 58psi. I've been running 80 psi but I'm looking at new tires and would like to know what everyone thinks about pressure: 58, 80 or somewhere in between.
5er with dual axles. Towmaster tires right now. Thinking Maxxis.
Thanks,
Jeff
What size, load and pressure is called out on the GVWR sticker?
What is the GVWR?
Otherwise I would be closer to 80 than 58.
