mileshuff wrote:
If you put max PSI in the tire but load it very lightly won't the tire wear in the center improperly?
You ever seen an ST actually wear out, short of bad axles/hubs? Frankly, I just can't tell a difference when I'm at 80 psi heavy or 80 psi light. I think the treads are stiff enough that you don't get a whole lot of bulge in the center and, if you do, the tires are still almost certainly going to age out before wearing out. Hell, even if you do wear the centers a bit, you're just making the contact patch that much better. :-)
Lyle
