stickdog wrote:
FastEagle wrote:
Cummins12V98 wrote:
Use inflation guide based on your actual loaded tire weight then add 5psi. This is per GY Tech Support.
Most RV's are loaded to the tires Max carrying capacity so that Max Psi is usually needed.
The real bottom line for tire pressures comes from the vehicle manufacturer as directed by the DOT.
In this 2013 GY document they support that fact.
GY Doc
FE
And my RV placard states Tires inflated to Max 110 cold PSI.
Doesn't say anything about a minimum so I keep them at 110 PSI
That is a CYA number that will cover the RV if it is loaded to MFG max load.
