lenr
Sep 06, 2013Explorer III
Correct Track doesn’t fit spring hanger
I’m in the process of adding a Correct Track system to our fifth wheel trailer to add 2” of height and provide room for 16” tires. However, it seems that the system expects 1 7/8” clearance inside the spring hanger for the spacer block and my hangers have 2” of clearance. Support claims that most trailers (larger than mine) use heavier spring hangers with only 1 7/8” clearance. This causes the Correct Track plates to pinch together at the bottom not giving enough clearance for the spring eyes. Support suggested adding washers to the middle bolt, but that seems to me to defeat the strength that the spacer block is supposed to add. The only solution that I can think of (that keeps some strength in the assembly) is to find a way to fabricate 2” spacer blocks.
Anyone had this problem?
Any other ideas?
Thanks in advance
Any other ideas?
Thanks in advance
