QCMan
Mar 16, 2021Nomad III
Just changed the factory equipment to an Equa-Flex but it is basically the same job no matter what you are putting in. Worst part of the job was jacking the unit up and getting it on jackstands. After that it was unbolt and bolt in new. If you get the wet bolts go for the bronze bushings too. 2182 miles on the original plastic bushings and they were about 25% worn through. Last trailer had about 6000 miles on it when I changed over and the plastic was completely worn through. It is a job worth doing.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
