CA Traveler wrote:
Cougarnewbie wrote:
The park has new 50 amp posts and older (suspect) electric.
What does this mean? Same old 30A wire with a new post and 50A CB???
A properly wired 50A circuit represents A LOT of power and the 50A CB should not trip.
It sounds like a bad and non code pedestal. Of course an intermittent short on the rig side is possible.
Can and do you know how to safely measure the voltage across the 2 50A hot legs? should be 240V +-10%.
Could use a schematic on how to test 240v with multi tester. Shouldn't each leg be 120v?
