Thermoguy
Sep 22, 2020Explorer II
WhitehouseLV wrote:Thermoguy wrote:
I have an Adco - not a toy hauler. I have zippers where I can unzip to access entry door, also the back has zippers on both sides. I'm sure you can open the ramp. No, you can not open the slides. Mine is going on 5 years old this winter.
Lots of posts on this forum about covers. Some like them some do not. I think if you get it really tight so it doesn't blow in the wind, it won't rub the sides. I like that I clean the camper in the fall, cover, then it is clean when I take it off in the spring. It is a lot of work so I put it on once and keep it on all winter.
did your Adco fit true to length? I'm at 39'11" and thinking I should move up one size as Adco choices are 37'1"-40' or 40'1"-43'
You buy one that is longer than the rig. The back has straps to take up the excess cover material. Mine cover is much longer than the 5th wheel, but never had a problem. I have also had some good wind, but never an issue with the cover. It also does not rub, I do use the material that came for the downspouts and have protected a couple sharp edges.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
