flyfishing48
Sep 11, 2017Explorer
Tom_M wrote:flyfishing48 wrote:I checked the specs on three weBoost units. Two stated 50 ohm impedance, one stated 75/50 ohms. Since your device came with RG-6 coax, you will be able to use the coax installed in your RV. Check the specs for your model to make sure.
My weboost came with a rg6 cable from the outside antenna to the booster, isn't that a 75 ohm cable? The label just st says says rg6
Looks like I am good to go.
About Fifth Wheel Group
