ugeesta
Apr 30, 2021Explorer
Crack at DeLam Fix - What to Do?
Question.
When you guys get your fiberglass walls repaired, how long is it supposed to last?
I had some delam fixed last fall at a local CW and it has cracked at the joint between the original surface and the repair area. The frustrating thing is this was the second fix for delam in this area. The first fix failed before I even took possession of the trailer after the first fix.
The unit was out of warranty and Jayco was kind enough to cover half the cost. This isn't a Jayco issue, this is a CW problem. I there anything I can do to get CW to fix this again on their dime?
Thanks.
Thanks.
