adamis's avatar
adamis
Nomad II
Jul 24, 2023
Bigfoot 2500 Front Fiberglass Delam Repair Questions
So as follow up to my previous two projects (holding tank supports and truck platform to raise camper) I'm now looking at the next big project. For years the front of my camper on the bottom portion (just below the cab pass through window) the fiberglass has de-laminated from the plywood. It hasn't really bothered me because it's invisible since it is between the cab of the truck. However... it is time to put this project on the to-do list and get it fixed.
The issue I believe at the root of this is that the support wall is insufficient which causes the camper to sag and expand whenever it is jacked up or placed on the truck. I believe this to be the case because the bubble (covering ~20% of the front wall of the camper below the overhead bed) changes in shape depending on if the camper is resting on the jacks or sitting on the bed of the truck. Also of note, when the camper is on jacks, the door of the camper will not open or close. This tells me the entire shell is moving.
I have a contact has a shop for fiberglass boat repair and he has offered to take a look to see what he might be able to do. The current idea barring any better ideas is to remove from bed of camper and support on platform so we know the shape it needs to be in the truck. Then we cut open the front fiberglass area to reveal what we have to work with. Unless they did something different than other areas of the camper, I suspect there is likely a 1/4" sheet of plywood across the front followed by 1" of foam. To add extra support for the camper, my current thinking is to remove the foam and replace with either marine grade 3/4" plywood or weld up an aluminum support truss to tie in.
Ideally we will get this new bracing to tie in with the front jack supports so we can keep the sagging / movement of the camper to a minimum when it is lifted and lowered. Once we are happy with the new support, we will re-glass everything so it is all solid and as if nothing had ever happened.
So my question is, has anyone performed this same repair or encountered these same issues? Are there any pics available to show how the front wall of the camper is constructed and how the front jacks tie into the support structure? Any suggestions will be much appreciated.
