N-Trouble
Jul 30, 2015Explorer
valhalla360 wrote:N-Trouble wrote:JeffPritchard wrote:
While we're at it...why don't HT trailer designers just move the wheels a few inches forward to reduce the pin weight?
Because it wont tow properly. A certain percentage of trailer weight (typically 15-20%) needs to be on the pin to tow straight and true.
Seeing as how you are limited on payload with the 1/2 ton I would seriously look at the new Aluminum version of the Andersen Ultimate 5er hitch. It will get you back a couple hundred pounds of payload vs some other hitches.
Is it helium filled? My hitchs wieghs in at around 200#, so you aren't going to drop a couple hundred pounds by going aluminim.
Far better to take the extra money from an aluminum hitch and just buy the right truck.
Let's try a different tack: OP, why are you so insistent on a 1/2 ton truck? A 3/4 ton doesn't cost much more and gives you a much better towing machine.
OK if you want to get technical 200lb vs 30lb for the Andersen is a 170lb diff. Happy???
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
