Hey guys,
I see that several of you have Ford F250 with a Curt Q20 slider. I recently swithched over from a GM to a Ford. My 5ver is about 120 miles away from here so I can't test hook it to see if I need to adjust the hitch up or down. In the GMC 2500, I had the hitch on the lowest holes to pull level. I know the Ford sits about 1" lower than the Gm did, so I am a bit concerned I will need to raise it to haul level.
Question to you all is which set of holes do you have the Curt set at in your F250's??
Thanks for all your help on this!!!
