jerem0621 wrote:
Those jaws are more than sufficient on the Curt...on the E16 of the slide bar was coming out then the hitch was defective...handle down = Locked....And it's a $275 ish hitch...you do not get top quality hitches for that money.
The Q20 in the picture above is a BIG heavy hitch. That center section is a block of solid steel...not bolted together sheet metal. The jaws are more than sufficient and the lockout mechanism is secure.
Not trashing the B&W it's a fine hitch too...
Thanks!
Jeremiah
If you are going to comment on the B&W please show the 20k Companion and Curt 20k then comment on the bolted together base. Oh there is not one. So please compare as close as possible.
