ksbowman
May 12, 2015Explorer II
As an ironworker for 38 years and welding for a living, iron (steel) is not wood. If you cut it too short you can always weld it back. Remember a weld is stronger than the base metal if you use the correct welding rod. I would not worry about it if it is a smaller 5th wheel just change it back. Welding back the pin would be simple with a cover plate.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
