Cummins12V98
Jun 08, 2013Explorer III
Lantley wrote:larry barnhart wrote:Cummins12V98 wrote:Lantley wrote:
4" hole saw
Too small!
The pipe is 4" . 4 1/4" would be better.
My total work experience has been in construction and including myself at times without the correct tool it is usually a bigger problem with the hole too tight.
tools are everything.
chevman
If we want to get technical what is the outside diameter of the hood or discharge cover being used?
It all depends on the model. Measure what you are using and size the hole about 1/4" larger than what goes thru the wall.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
