Cougarnewbie's avatar
Cougarnewbie
D to E on stock wheel?
Hi All
Last season I had to buy a tire on the road. It is an E rated tire at 80 psi. My stock tires are D rated at 65 psi. Now I have 3 tires at 65# and 1 at 80#. I need to replace my spare and would like to buy a mate for the E tire and put it on the same axle, and use the used D as my spare. My wheels are the common white 8 spoke 15" 6 lug wheels. Confused? My question is how to guarantee my stock wheels can handle the higher pressure? There is nothing stamped on the back of the wheel, except made in China. And I have high pressure stems.
My Cougar is heavy. I like the idea of an E (beefier) tire. The E tire has "Standard Rim" stamped on the side wall.
Thanks
AL
  • The usual white steel 15" wheel is good for 75lbs. So it can take a 65 lb D but not an 80 lb E.
    IMO put the new tire ( a D) on the fourth place wheel and use the E for a spare with PSI at 75lbs.
