- OutdoorAddictExplorer
Grit dog wrote:
Yes they're for the most part known as junk tires. Hope they were warranty...free, if not return em.
Nexans are total junk tires!!! I bought a new 2016 and had the dealer balance the tires before I would buy it. I had the tires balanced again by the dealer under warranty before I left on a 9000 mile trip. I stopped 300 miles from my home and had Firestone rebalance them, and then had the Dodge dealer in Colorado inspect them and they Road Force balanced them. The truck vibrated still, took it to Dodge when I got back home and they said it "performed as designed". The manager flat out told me that he was suprised that I even got 17000 miles out of the tires, but even if Nexan warrantied the tires they would be prorated. I had enough and replaced all 6 tires at about 17000 miles with a new set of Michelins and I had them installed by a local tire shop and still had some vibration. I went back to Dodge and paid them to road force balance the tires and finally, finally no vibration. Lessons learned, the Nexan tires are total junk, replace them, and get someone to balance your new tires who has a lot of experience balancing dually tires. - towproExplorer
dennych1 wrote:
I will be running Michelin let 235/80 17ELTX 2 looking at a 2010 Arctic Fox 990. I am worried about have to upgrade wheels and tires which is not in the budget.
Can you get same size tires with a higher weight rating then 2835 lbs for dual rear wheel.
Thanks
Dennis
That means 2835 PER tire when used in dual tire configuration. So take 2835 X 11,300 lbs total weight at 80 PSI.
Since the rear is only rated at 9750 lbs, they recommend (on door sticker) to only run 65 PSI in rear tires fully loaded :).
I also have a ram dually 4x4 diesel with the nexan AT's. I found running 70psi just felt a little more stable to me loaded, but I am still under rear GAWR and even under GVWR with my 990 fully loaded. mkasner wrote:
Anyones Nexans vibrate their Ram DRW any? I have noticed more and more vibration in our 2016 3500 even after having 6 new Nexens put on last week and balanced twice
Yep, my neighbor bought a new RAM dually late summer of 2016 from Dave Smith (75 miles from home). It came with Nexens. The truck vibrated on the way home.
He went back to Dave Smith, they rebalanced the tires.
No change.
At that point Dave Smith refused to do anything more.
Neighbor bought new tires and when he headed south, he left the tires with me and I sold them on Craigslist for him.Grit dog wrote:
Totally agree based on my experience above.- Grit_dogTrailblazerYes they're for the most part known as junk tires. Hope they were warranty...free, if not return em.
- mkasnerExplorerAnyones Nexans vibrate their Ram DRW any? I have noticed more and more vibration in our 2016 3500 even after having 6 new Nexans put on last week and balanced twice
- finsruskwExplorer34,000 miles on my Nexans hauling an 1181 Lance w/no issues in my 2015 Ram DRW 3500.
- Grit_dogTrailblazerDually = no weight worries with your setup regardless of tire. You have a 9000lb +\_ tire capacity in back.
- dennych1ExplorerThanks for the info you really helped
- jmckelvyExplorer
Thanks
Dennis
You will be fine with those tires. I've run the stock size LT235/80 R17 for more that 200000 miles (not same tires :)). You don't need to upgrade them to carry a 990.
My truck and camper fully loaded for a loooong trip puts about 8000 lbs on the rear axle. Not even close to the 4 dually tire ratings or the rear axle rating. The camper adds less than 200 lbs to the front axle. - dennych1ExplorerI will be running Michelin let 235/80 17ELTX 2 looking at a 2010 Arctic Fox 990. I am worried about have to upgrade wheels and tires which is not in the budget.
Thanks
Dennis
44,066 PostsLatest Activity: Oct 04, 2013
