partsman01's avatar
partsman01
Damp/wet carpet
So have not covered fifth wheel yet, and had lots of rain, carpet on left side of slideout felt damp, then we got hit with heavy rain and now hand comes up wet on only that one side, I thought seal looked good on our 2004 wilderness lite, but maybe it comes in from around the moulding on it.
Gonna try figure it out, but will hope to get it covered soon as we are supposed to get some sun soon.
  • thanks for the input, i at least got cover on and do have my three small heaters in
  • OK, I would climb up and look at the outer molding closely where it makes the 90 degree angle. I had one that had a big crack/opening where the vertical met the horizontal at the top corner. After sealing that up my damp carpet along the edge of the slide went away.
  • No it was in and I thought it was level but may be low at back
  • On my last one I found that problem stemmed from the mounding on the roof of the slide. BTW did you mention what position the slide was in, I assume out?
  • Take care of it right away! Water doesnt take long to do serious damage. Get it to the dealer so that they can properly seal it.
  • Door, windows, marker lights can all leak. If you want to know exactly where its leaking get a seal test done.
