Racine96
Apr 05, 2015Explorer
You're speaking of a 2015 Montana with a Dometic thermostat. Do you have 2 AC units with heat pumps? IF so, if like our Mobile Suite there are 2 zones and the furnace will only work on zone 1. Just sounds coincidental that you might have same problem learning curve as Mobile Suite owners. If that would be the case dealer may not even be aware not that that should absolve him from caring. Just a thought. When we picked up our new Mobile Suite no one including the Rv personal or other Mobile Suite owners new how to use that Dometic thermostat to turn on furnace. I doubt there will be anything actually wrong. Good luck.
This why I was trying to say. It is interesting that in your Mobil Suites is on Zone 1. In my Columbus, the furnace is controlled only in Zone 2. Maybe he needs to play with the thermostat. There might not be something wrong.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 09, 2026
