debbieboston's avatar
debbieboston
furance filter
Where is the furnace filter on a 2002 Winnebago adventurer. The manual says it is under the bed but we can't find it or don't recognize it. Does anyone have a picture, diagram or better description?
  • There is NO Furnace filter. That Filter on your model is IF you have the basement model AC or Heat Pump. That filter is for the AC/HP system and not for the furnace. Doug
  • Typically there won't be a furnace filter of any kind, but there will be a A/C filter.
  • debbieboston,
    Ours, is under a lift up panel, in between the passengers side of the bed and, the night stand. However, our coach is an '04 Itasca Horizon 36GD with the C-7 330HP CAT so, it's most likely a bit different than yours. But, if you have basement A/C, you should have that filter in that area, close by where ours is.
    Scott
  • Mine is under the bed, there is a small hole to lift
    the panel off the filter.
