- BumpyroadExplorerjust saw some at walmart. $200 and $239 IIRC.
probably come off the same line in China as those costing $500.
bumpy - Fire19ExplorerDo not get the cheapest one out beware they are cheap for a reason. We have been out of our stick built since Jan 1st when our Cheap dehumidifier (2 yrs old) caught fire and smoke and sooted the whole house we are down to studded walls. Look at the Consumers reports to find a good reliable one.
- path1ExplorerWe had 3 or 4 over the years. They all did the job but the best one for me was one that was flat on top. Put it right next to my chair and the flat top worked perfect for "end table". Also get a couple gauges so you can see if its doing its job through out your rv, not just close it. I use 3 of these in different spots. They are for cigars storage boxes but work great to check humidity. https://www.walmart.com/ip/Xikar-Digital-Round-Hygrometer/713812767?wmlspartner=wlpa&selectedSellerId=1148&adid=22222222227099464021&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=218736396865&wl4=pla-418505689837&wl5=9033330&wl6=&wl7=9033322&wl8=&wl9=pla&wl10=112562587&wl11=online&wl12=713812767&wl13=&veh=sem
- 2oldmanExplorer IINot hot enough to run air?
- donn0128Explorer IISearch online for ratings and pick the biggest one with the highest rating. You wont go wrong. Pump? Naw, dont need one. Set it on a table with the hise sticking out a window. Done!
- Isaac-1Explorer IIMy solution is to put it in the shower and let it drain to the 40 gallon gray tank.
- gboppExplorerGet one with a pump. You can drain it out a window or into a sink.
It's much easier than emptying the tank one or two times a day. - Isaac-1Explorer IIWhichever one you can find cheapest in your local big box store
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 23, 2026
