Ahh, the Northwest passage as we called it here in Texas. The most traveled route to Colorado and back there is. It is an RV friendly route. Depending on where you are going In the DFW area, try and not take 287 thru Ft Worth, the most expensive expansion/revamp ever is from the I820 loop on the north side of FW on south to I30. If you are going to the North Side of Dallas, cut off at Decatur, TX on 380, across thru Denton and then go on towards Mckinney, you can then go down to your Destination from several other routes that way. Just try and stay away from Dallas proper.
