M_GO_BLUE1
Apr 21, 2008Explorer
For those of you that will be picking up your unit soon here are some things I found:
Make sure your valves to the dump tanks are closed before you start using, make sure the drain plug to the water heater is tight, and check your sprayer on the kitchen sink (ours was cracked but don't ask how we found out), make sure your valances are tight (that's from Dave), careful when you go up or down a driveway as the back end of the unit is low (landing gear), the Lazy Boy/dinetter table goes out first then the sofa slide goes out, sofa slide comes in first then the Lazy Boy/dinette table slide, the outside flap that looks like an outlet for the central vac system is not an outlet but is actually the exhaust for the central vac, there is a sliding drawer in the base of the couch along with two cushions that come up and reveal more storage, unplugging the 50A cord from the unit is hard so be patient, careful when you use the awning as it does not react to water or wind so probably best to roll up if you will be gone for a while (while at your campsite), and if I think of any more I will post
About Fifth Wheel Group
